Ravi
Hi. I am afraid that I am on the mooch for help and advice, again.
I am fitting an 80W solar panel to the boat this winter and I am just about to fit the regulator and I have a few questions that I hope someone can answer. If these questions seem very basic (dumb), my apologies. I have picked up bits and pieces of information from the forum and the web and would really appreciate it if someone can tell me if I am on the right track.
On the recommendation of a fellow forum member, I have bought a dual power solar regulator. (10A dual battery solar charge controller / regulator with a remote LCD display and cable for 12/24V batteries). It has one input for the solar and two separate battery 'outputs'. The charger will charge the battery connected to output 1 first and, when it is fully charged, switch to battery #2.
My battery setup is the traditional - 1 x Engine start battery + 1 x Leisure battery with a Battery switch can select either, both or neither battery.
Question 1 - The regulator manual says, in Bold, .... "Note: independent charging assumes that batteries should be electrically isolated from each other, i.e. they should not be connected to the same system." Will this be a problem on the very rare motoring occasions when I have my battery switch set to "Both"?
Question 2 - The regulator has connection points to allow two wires for each battery. These are similar to the brass screw down connections in a domestic plug. Can I use standard domestic or automotive wire? (Heavy duty wire could be a bit of a squeeze to get it into the terminals on the regulator.)
Question 3 - (This is where my lack of knowledge and experience gets really embarrassing.) My batteries are currently connected (only) to the switch. as shown in the photograph. To add the connections to the regulator, is it as simple as popping another ring crimp connector on top of the existing (switch) ring connector and screwing the plastic tap thingie back on?
Question 4 - My Googling and reading of forum posts have made me aware that it is advisable to have a fuse between each battery and the regulator. The regulator has a rated load / charge current of 10A, so I was going use a separate 10A fuse between each battery and the regulator. Is that correct?
Question 5 - (Another question of ignorance ).... I am uncertain about what to buy for the inline fuse. I am aware of the cylindrical white plastic inline fuse holders in cars and I believe that you can also get inline holders for blade fuses. Can anyone advise me what type is advisable, if it matters? (All my other boat fuses are 'blade' fuses.)
Any help will be greatly appreciated.
Rav.
Rav.
