tim_ber
The power cable from the radar display is too short to get to the power.
The cable consists of a thin positive and negative electrical wire, lots of padding and insulation, a braided (shield *)? wire and then really thick insulation.
(*But the plug to the back of display has 3 pins, so is the braid a ground? What is a ground, where should it go? Positive to positive of switch terminal and similar for negative, do I need to do anything with this braid?)
Can I make up the shortfall with ordinary cable or do I needed this special braided stuff? Can I use 'ordinary' 3 core?
Will make it very difficult to run the rest of way if I need 'proper' cable, also how do I join the braid?
I know with vhf co-ax the only way to connect wires such as this is via connectors and no soldering owing to braid losing impedance etc.
What is the briad on the cable?
It is only the power to the display after all.
Thanks in advance and ignorance.
