DAKA
I will try it and report back.
I want to leave the genny tank completely empty of petrol so I can stow it inside ( weight distribution issue).
I will attach a rubber hose to the float chamber with a Tohatsu connector to it, then I can just connect and disconnect my remote OB tank.
By running the carb dry after use as I do with the OB , I should minimise gumming.
I will reduce the tohatsu to 75:1 and run 98 ron.
I can brush the plug once a month, say 3 times during the season, not really a big deal, I used to clean the seagul plug each time I started ( 10:1 ).
