ChasB
Just bought two strainers at a much reduced price from ASAP. They are made of gunmetal.
Owing to an error in measurement the ports are 1.5" BSP, and the hosing on board is 1.25".
I could replace them but I'd lose over £100 in the process, plus the hassle.
I've scoured the internet but can't find any hose tails that go from 1.5"BSP to 1.25" - though every other combination of sizes appears to be available!
However I've found this Aquafax DZR CONNECTOR 1 1/2"BSPT - 1 1/4" HOSE thingy.
Will this work? Or is there a danger of galvanic corrosion?
The boat is primarily used in fresh water, with (at most) a week of salt water each year.
I've also found this 1 1/2" BSP for 32mm or 38mm ID Hose Plastic Skin Fitting. Would it be completely barmy to consider this?
