DavidJ
I'm fitting two new turbos to my KAD43's and the recommendation is to prime the turbos with oil then crank the engine without it starting to make sure that you have a constant supply of oil to the turbo before running the engine proper.
Is there a way of activating the stop solenoid (which I think is the way to do it)
Also I guess for those who regularly fit these things do you do any more than just prime the turbos.
Cheers
David
Cheers
David
