Can I crank a KAD43 without it starting?
DavidJ
15 Jun 2001
I'm fitting two new turbos to my KAD43's and the recommendation is to prime the turbos with oil then crank the engine without it starting to make sure that you have a constant supply of oil to the turbo before running the engine proper.
Is there a way of activating the stop solenoid (which I think is the way to do it)
Also I guess for those who regularly fit these things do you do any more than just prime the turbos.
Cheers
David
There is a lever on the side of the injection pump with nothing connected to it. Twist this lever against the spring and cable tie it in position then crank without starting.
Firstly thanks aquatom for advice.
I bought two turbos from Turbo Rebuild Limited for £1584 incl vat and delivery.
These are genuine new Borg Warner units
They do rebuilds for £200 each but my exhaust housing looked very shot and parts are difficult to obtain.
I'm going to buy the gaskets from Keypart for about £18 each
I'm taking volvopauls advice and completely draining the coolent
Also advised is to have an oil change so nice oil goes through your expensive turbos
Thanks for the info
Considerably less than from VP, keep us posted on how the install goes
Cheers Dave
I read a thread on here where it was not recommended to crank engines without starting, as the exhaust silencer fills up with water when there's no exhaust gas pushing water out.
