peter2407
I have an Audi estate where the battery is in the spare tyre well in the boot. Assuming I can tie the boat battery down, can I charge it whilst driving using my jump leads? Any tips/concerns/comments?
Thanks Vic. Similar type - by which you mean wet cell with wet cell? That might be a problem ....
Maybe some system you could use from the caravanning market where they charge the caravan battery while driving.
fit a split charge relay problem solved, light duty cable runs and no risk of feeding battery to starter.
Deep cycle boat batteries are not compatible with a car charging system!Compatible with the car charging system is really what i should have said.
Many boats also have car alternators with simple internal regulators often set as low as 13.8 volts. Deep cycle batteries need a multi stage regulator set to their gassing voltage of 14.4 volts or higher otherwise their is a high risk of sulfation. Batteries need to gas slightly to reduce sulfation and to stir up the electrolyte to stop damage due to the acid settling at the bottom of the battery - stratification
So can you use the car to charge the boat battery - yes - but it's not best practice, batteries will die sooner if not charged correctly - but I suspect your boat alternator is the same type with no external multi stage charger added.
