Tim Good
I’m rebuilding a Lofrans anchor windlass. The new brass part in the middle of the photo is meant to slide down into the lower older part with small tolerance of around .1mm.
However the inner diameter of the old section should be 100mm but instead it’s now 9.13. That’s a huge difference. As such the new brass unit just sits on the top of a lip.
It older based hasn’t distorted in shape but simply not big enough and more. I have had to heat it all to get it apart. Do you think it could have shrunk that much in the process?
