thesaintlyone
When I got the westerly it had an old camping Gaz 2 burner stove on a gimbal above a large empty space about a foot deep with no outlet holes for any gas pipes etc.
It also had all the pipework etc removed.
I have purchased a new Kampa two burner stove and mounted the gimbal on top and placed it above the space (pictures to follow cant seem to do this on a mobile)
I was going to use a small camping gas canister the disposable type but apparently these are not designed for the stove in question.
So the question is if I use a camping gaz R904 1.8kg butane Gas refillable cylinder (the smallest) which I presume the previous owners did due to lack of holes exiting the aforementioned space can the cylinder sit below the stove or as I have seen on some boats do the pipes have to lead back to a cockpit locker or is there another option.
Please bear in mind the only cockpit Locker on board also holds the petrol tank for the outboard. ?
Many thanks
Duncan
Many thanks
Duncan
