westerlylad
Active Member
Can anyone advise me how this fridge works please? I have one which appears to be lifeless whether 12v or 240v is selected. Cheers.
I think the name provides a clue.I had no idea the fridge also ran on gas.
If neither works suspect the small heating element has failed, does it draw any current
My 'combi' fridge takes a couple of hours before the element starts to get really cold. Once it is going all is fine.Thanks to all who replied to my original question. I've now managed to get to the workings of the fridge and have found that:
1. It has never been connected to the gas supply, so presumably the original owner agreed with most of you that a gas powered fridge on a boat is not ideal.
2. It is also not connected up for 12v either, so presumably the original intention was that it would just be used when connected to shore power.
3. I've connected up my shore power lead and switched on. After about half an hour there was plenty of heat coming from the pipework at the back of the fridge but no sign at all of any cooling of the fridge element. Same situation after an hour by which time I had used about 0.1 kW.
I guess I have some other problem with the fridge, perhaps something to do with the refrigerant. (perhaps there isn't any!).
Thanks again for all your suggestions.
