Ian_Rob
Just wondered whether any forum members have the Amtec Camino 108w Transponder yet and if so, their views on it?
I would think the 108 (108W without wifi) replaces the 101, which has no wifi possibility and is what I have but not yet installed.It has integrated wifi and replaces the 101 - I think.
Depends how much that is ... and from whom. I bought from Milltech Marine, which the last time I looked didn't advertise the 108/108W. I've seen some silly prices in European outlets for the 101 - up to double the MM prices.Thanks. The 108/108w seems good value pricewise.
Hmm, seems a bit pricey to me - unless you must have the Wi-Fi version the 108 has quite a saving.A German supplier seems to have the wifi version for £497 incl delivery to the UK and tax.
@Ian_Rob
I presume you have read the following two threads ???
http://www.ybw.com/forums/showthread.php?382812-Cheap-Chinese-AIS-Transponder
http://www.ybw.com/forums/showthread.php?383694-Cheap-Chinese-AIS-Transponder-ordering
Only you can know how you intend to capture and use the data. For me, a cable and USB adapter is quite suitable, the present set-up that the 101 will replace is a receive-only unit in a cupboard above the chart table with the USB cable to the netbook just below; simple and effective. If you need to access a wifi-enabled plotter or PC sited elsewhere I can understand the requirement.I am basically wanting an AIS for the new season and looking at all the possibilities. I am not sure whether wifi is worth it or not?
I think you are right, a separate switch, cable and plug to the socket that shorts some pins. But I still maintain it is a physically inelegant solution. It also seems to have a further functionality, to activate a SRM transmission.I believe that the transponder silence function can be achieved with just a toggle or key switch and that it isn't necessary to buy the optional switch box.
