Wansworth
Changed the cam belt on my Lambardini as it was at least twenty years old.Thiscaused mild surprise at whyI should bother.ShouldI have bothered?
Absolutely yes. Cambelts can look great on the outside but frayed to tatters on the important inside toothed bit.
Ideally mark the new belt with Tippex showing date - and engine hours if recorded.
My chum always does this for date and milage - he's a serious car mechanic involving high end or racing cars, he makes a good living on cam belts.
A great idea in principle. However, most belts I have worked on have an idler/tension wheel which bears on the smooth side of the belt so I don't think that Tippex will last very long.
Richard
I've never changed one on an outboard. Should I?
The life of a cam belt is debatable, with age being very important. I know, because I have just scrapped my car due to a broken cam belt that had done 30,000 miles and was nearly five years old. Cam belts can jump a tooth causing the tappets to chatter. Had I known this....
This is incorrect. It is possible for a belt to jump a tooth, usually resulting in poor performance, sometimes resulting in bent valves.
Well, my Peugot Diesel jumped a tooth because of some debris from adjacent belt.
Had to scrap car, even though belt was less than 30,000 & 5 yrs.
