wonkywinch
The drain function isn't automatic, only the overpressure. To drain the tank you need to push the lever down, again from the manual "During the cold season, if the water heater is not in use, it is advisable to empty it using the valve lever. This is toThis calorifier produces hot water from the Incoloy electric heating element. Also featuring a safety / non-return valve that allows discharging of the water heater in case of disuse, set at 6 bar (±1). (Taken from Quick Calorifier 22 litre manual). So it might actually be doing it on purpose because the boat has been idle for some time.
avoid damage caused by frost".
See my, and others posts about the routine maintenance (operating the lever) needed to prevent leaks.
