msimms
Had a very similar problem after installing a thermostatic mixing valve and increasing the thermostat temperature. Adding an expansion tank resolved the problem.
I have the same calorifier but with an expansion tank. I've never noticed any water out of the prv.
I don't have an expansion tank. I've come to the conclusion that fitting one is the logical solution![]()
Have a lo0ok at this Alt
http://www.ebay.co.uk/itm/Coolant-r...558?pt=LH_DefaultDomain_3&hash=item339eb62e06
That will be of no use at all.
Can you explain that please?
That's designed to collect coolant when expelled from a rad cap, here we are talking about a lot bigger quantity, and higher pressure, as the water gets hot it expands, if its got nowhere to go it will get pushed out of relief valve, the whole idea of the expansion vessel is that it has a bladder inside that expands to take up the excess pressure and when it cools can retract without he need to expel any water out of relief valve.
There will always be a small dribble, so I discharge it into a bottle in the bilge. If that fills up regularly - I find out what caused it. (The bottle overflows and runs into the bilge.
Just another thing to check 'regularly'
I have the same problem on my problematic Bavaria, replaced the leaking PRV late last year, but the new one has started passing since. went to the boat yesterday to replace with another PRV, but was missing a nipple so couldn't complete.
Read this thread last night, so this morning have purchased and fitted an 5 ltr accumulator.
Will report back on if it works
