KevO
I know what they do but do you really need both? Space is a little limited so I could prob get away with a 2L one, maybe 2 of them at a real push but are they both absolutely necessary?
As Vyv says, they're not essential. I don't have either on my boat. If you have hot water piped to the heads, there'll probably be more than enough hose to cope with slight expansion.
But with simple pumps it's the other way round. The accumulator will prevent it cycling, and will also serve as an expansion tank (takes up the extra when the water in the calorifier is heated and so expands. However the expanding hot water will get into the cold water pipes. If your system has a non-return valve to prevent this, you will also need a separate expansion tank.You should have an expansion tank but you may not need an accumulator, it depends on your pump. I have one that has a bypass that stops it cycling.
I have neither and all works well. Without an expansion tank the NRV on the calorifier will open to let out and excess pressure. I have a 0.5l container to collect this and empty it occasionally.
Www.solocoastalsailing.co.uk
I think you mean the pressure relief valve?.
Mine was exactly like this when I bought my boat. The result was that not only did the water system judder when the taps were turned on and the pump activated, but also there was a steady leak from the PRV.I have to admit that I have never completely understood my system. It has an accumulator and a PRV with a non-return valve included, an odd item that was hard to source when it needed replacing. I have never had hot or even warm water coming from the cold taps, so it works for me. It will work with a failed accumulator but is better with one, and currently, touch wood, has no leaks and will not normally pump in the night.
I have neither and all works well. Without an expansion tank the PRV on the calorifier will open to let out and excess pressure. I have a 0.5l container to collect this and empty it occasionally.
