Spi D
thats a good plan, my strainer is already above the waterline for exactly this purpose and it has a clear lid, this is how i know its not getting enough flow is that it must be sucking in a lot of air (can see a lot of bubbling at high rev, and very little flow at idle. have fitted new impellor too! I know that the pipe on the intake (where the bellows are) is not perfect and am very suspicious of this area. Plus, its an inch pipe, that feeds an 1-1/4 inch system - this must be a bad restraint. Will check over the weekend to find any air leaks by back pressuring the system with water, and duct taping the little inlet holes. this should show any leaks pretty well!
i will probs come up with a flush system, and luckily am fairly close to a small private lake where I can test it.
Trust me, when it comes to drilling a ratherly large hole in the bottom of the boat, i am well aware that this is not one to get wrong..!! and also need the stop cock straight onto the intake too - taking no chances on this one.!
cheers for the help so far - cant wait to get on the coast !!
Agreed - if the original intake is not working and not mendable, the safe way is to isolate it. If OK but insufficient (unlikely), I might consider keeping it, running both in parallel up to the filter.
Regarding water flow through leg to cool things: If no pump is drawing water in, the flow will be minimal or at least out of control.
