Calor Gas Regs.
Tranona
10 Nov 2007
There is nothing legal to prevent you from working with gas yourself. You can get good information on standards and good practice from Southern Calor in Southampton. However if you are on inland waterways you will ned a BSS certificate which does have specific requirements and a need for a check. On a seagoing boat you can also have an inspection and test certificate, but this obviously costs and you may find it better to have the whole job - or at least the gas connection and pipe runs done by a qualified person who will provide the certificate.
Bobobolinsky
23 Feb 2007
Cambridge Fens
Yes it is simple, but just make sure that you test everything with bubbles
If you have not got a bubble chamber fitted, I can heartily reccomend fitting one. I have a lot of experience with gas, having owned a gas company, but I fitted a bubble chamber to a boat and "discovered a leak". I went through the whole system and discovered that one of the valves on the cooker was passing slightly. A potentially lethal problem solved.
Networks
27 Jul 2009
Med
Although you may be able to do the work yourself, check your insurance. My insurance specifies that I have to have a gas inspection / test certificate for the boat and it must be by completed by an approved gas engineer. When I had the flexible pipes replaced as they have to be every 3 years I think, (I may be wrong on the time here but it is something like that) the engineers charge was very reasonable and came with a certificate for the boat on payment of the bill. On saying that I got a number of quotes and some were 3 times more than I paid!
VicS
13 Jul 2002
Fitting a bubble leak detector is an excellent idea.
You should check any joints you make with a leak detector spray, esp those before the bubbler. While a solution of washing up liquid is effective it is not recommended because it leaves a corrosive residue.
http://www.socal.co.uk/Nova-Comet-Leak-Detection-Spray/29/16470
If you are not familiar with compression joints you may find the following useful
http://www.calormarinegas.co.uk/Compression
Reference has been made to the Boat Safety Scheme (BSS). LPG installations are covered by section 7:
http://www.boatsafetyscheme.com/downloads/BSS_Guide_chap7.pdf
26 Nov 2009
everywhere
Is it advisable/legal to carry out D.I.Y gas work - replacing flexible hoses & regulator in gas locker.
Advisable? Depends on your skill level. I do it both on the boat and at home but maybe some day I will pass you on my way to the stratosphere!:D
Legal? Who cares? Who is likely to shop you?
Heckler
24 Feb 2003
I used to work on offshore oil production platforms, the last one produced H2S, I was maintenance superv, the pressures in the vessels and pipes were anything up to 5000psi and we were re injecting gas using 4000 hp compressors. I used to strip and rebuild all sorts of equipment that had these pressures. I would argue that that experience alone gives me the knowledge and expertise to change a simple rubber gas pipe on a boat!
Stu
Heckler
24 Feb 2003
How many insurance companies specify that LPG work has to be carried out by registered engineers? Even then, insurance companies can claim that work was negligent.
Remember a couple of years ago when europe said that we couldnt do electrical work any more in our houses? Well that turned out ot be twaddle, as long as someone can prove they have a some expertise then they can go ahead and do what they have been doing for years"!
Stu
pvb
UK East Coast
Stu
Doesn't mean you're qualified! ;)
prv
29 Nov 2009
Southampton
Nothing to do with Europe.
Some MP's son-in-law put a screw into a wire while putting up shelves in his kitchen, and electrocuted his missus. "Something must be done!!", so they did "something", despite the fact that the accident in question had nothing to do with amateur electrical work.
Jean
17 Nov 2001
South
Now we are talking “part P” (of the Building Reg’s). Recently spent a couple of years as electrical contracts manager for a local council, what a waste of time and money part P is!
