MagicalArmchair
Okay, so I've had a very rapid response from Rydlymes director of sales no less:
This leaves me not a great deal clearer (seeing as we don't have a fresh water side on a 2GM20) - the diagram was interesting though. Question - So, err, does the water come out of the block the same way it goes into the block? Via the Thermostat? .
This is from vyv_cox on another related post here: http://www.ybw.com/forums/showthread.php?378468-Yanmar-thermostat-not-closing/page4
Which is very useful
The instructional sheet that we provide is intended to be as generalized as possible so that we can cover most systems. As an example; on most inboards, the thermostats are only on the freshwater side and do not require to be removed to clean the raw water side. As far as your Yanmar 2GM20, we have had numerous customers successfully flush these motors using RYDLYME Marine. I have attached a diagram of your cooling system which shows that removing the thermostat should free the path to allow your entire raw water system to be cleaned.
By all means please let me know if you have any additional questions or concerns.
