BabaYaga
There is no problem, I just have a few questions to try and improve my understanding...
Engine is a three cylinder Beta 722. Unlike on some other engines, there is no relay for the glow plugs. They are fed directly from the engine panel by a 2.5mm sq wire within the engine harness.
The current draw of the plugs is not to be found in the engine manual, but recently another forumite posted a link to the workshop manual for Kubota diesel engines, including the D722, upon which my Beta supposedly is based.
This manual says the glow plug should have a resistance of approx. 0.9 Ohms.
Since there are three plugs in parallel, I calculate the total current draw to be 40A (12V nominal, disregarding the wiring).
1. This current is a lot more than I expected, is my calculation correct?
2. The engine panel itself is also fed by a 2.5mm sq wire within the engine harness. There is also a 40A fuse in this wire. Provided that the answer to question 1. is yes, doesn't the wiring appear to be a bit marginal?
3. The engine harness has a length of about 3 metres, so the total length of 2.5mm sq wire supplying the glow plugs is some 6 metres. When I try to calculate voltage drop over this run. I get 3.33V or 27 percent. Does this sound normal/reasonable?
Thanks for any input.
