nathanlee
What's the leeway in terms of current capacity on electrical cable?
i.e. If I have cable rated at 15amps, what could I safely get down it for a short burst of a few seconds or so, perhaps a minute?
I realise the "proper" answer is going to be 15amps, but what's the real life answer if I needed to do it in an emergency?
The reason I ask is that I've used 15 amp cable to feed the switch panel, and off that is the autopilot, which is fused for 10amps, as well as an inverter. The draw on the system should never be more than 15 amps continuous, but it is possible that if I had the VHF keyed up, the inverter on, and the AP cranking the tiller at full power, then it'd peak above 15amps.
