C-Warm water heater pressure relief valve
  • Thread starter Thread starter Ric
  • Start date Start date
Ric
8 Dec 2003
I removed the pressure relief valve from my C-Warm water heater today in order to de-calcify it. Unfortunately after unscrewing the spring-loaded plunger, the needle fell out before I could note the correct orientation.
The needle can actually be refitted in either direction, but after a lot of examination I decided that the orientation in this photo is correct. With this orientation, a dimple on the end (right end in the photo) fits into the bottom of the barrel of the the valve.
Is this correct?
I could not understand the purpose of the needle - any explanation gratefully received.
Bonjour Ric,
No pic visible in your post. I have a C warm calorifier 20 litre vertical model and may be able to help. to add photos to post on this forum you need firstly to upload onto photobucket and then copy img code into post.
Sorry I can't help other than to suggest you reassemble it as you have described and then pressurise the system and press the release button to see if it is operating correctly.
I think you'll find this rod is the temperature part of a combined pressure and temperature relief valve. So when it warms up it pushes the plunger to relief the pressure.
Changed mine last week and threw out the old valve so can't see how mine worked!
I had a similar problem with one of these and tried to fixit... gave up and got new one from web site... Not expensive if I recall...
