C**P tank full - won't empty - Help
Jegs
7 Jul 2007
The Sealand tank monitor is indicating full [I suspect the high level led has failed] & the extraction pump only pushes air. The circuit diagram shows connections to both float level [high & full] switches and I suspect that lifting the tank cap might cause the float to drop & enable the pump to operate as desired, but life's rarely that straightforward. If anyone has any experience of dealing with this problem, I should be much obliged for some advice.
Hopeful thanks,
John G
NickTrevethan
3 Dec 2011
London
Would a gentle tap with a small hammer not help loosen the sender?
On another boat the fuel guage would stick when we were heeled, but a very gentle tap to the top of the tank on the plate holding teh sender would set it sliding back to the level of liquid.
cheers
Heckler
24 Feb 2003
Hopeful thanks,
John G
First of all get out the Marigolds!
S
Jegs
7 Jul 2007
Thanks to all of you. The tank was empty & can still used [even more phew! than you can imagine]. I shall a tap, but they installed the seating after fitting the tank.
a a
John G
