Soton sailor
I'm perhaps coming to the conversation a bit late, but maybe I can help a little (I'm a naval architect specialising in aspects of stabilty).
As mentioned by the other well-informed posters, stability is a double-edged sword. A vessel that has a small amount of stability (which can be quantified as a small metacentric height), will for a given energy input such as a gust of wind, heel over to a large angle. However, with a proportionally small righting moment, she will take a while to roll back upright and will slowly oscillate through larger angles until coming back to rest. A vessel with larger stability (which can be quantified as a larger metacentric height) will, for the same gust of wind, heel to a smaller angle. However, as she rolls back, she will do so with a greater "speed" of roll. The stability for ships is a balance between heeling so far over that gravity assists the deck cargo off the vessel, or rolling so fast that the forces from roll acceleration do similar! As a very crude example, based on a "static" waterline, an example vessel with a metacentric height (aka GM) of 0.15 metres (the legal minimum) and a typical mass distribtion would have a roll period (upright to extreme port to extreme stb to upright again) of around 40 seconds, whilst increasing the GM to 0.50 metres would reduce this to around 23 seconds for the same mass distribution around the centre of gravity. Increasing the GM further to 1 metre would bring the roll period down to around 16 seconds. For the same three examples of metacentric height, the list angle for the same gust of wind would be 7.6 degrees (GM 0.15m), 2.3 degrees (GM 0.50m) and 1.1 degrees (GM 1.00m). This book has some plain-English explanations in more detail.
When combined with the dynamics effects of the sea, and the hydrodynamic reaction of the hull to the forces around it, it becomes rather complex! In extreme cases, excessive stability can be very dangerous - a sad example (where excessive GM was a contributory factor) was the Chicago Express containership accident in 2008 (a quick Google will provide lots of analysis and a detailed accident report).
