Champagne Murphy
10/1 the draft is with the publisher & he is spending the advance on a glitzy holiday
If he's done it that fast he's probably in a darkened room with a cold cloth on his head
Down to earth, practical advice without the bling. Nice!
Having looked a lot at AIS, but not yet taken the plunge, I was very interested in your comments. What system did you use?
I dont know your boat nor the preparations you made, but coating the bases of bulbs with a suitable grease or wax will avoid corrosion issues. If the bulb is low powered then waxoyl is good for protection - obviously dont coat the glass.
You seem to have had disproportionate electrical problems. I dont know your boat nor the preparations you made, but coating the bases of bulbs with a suitable grease or wax will avoid corrosion issues. If the bulb is low powered then waxoyl is good for protection - obviously dont coat the glass.
This problem should go away as people switch to LED lights (proper ones, not conversion bulbs).
Really interesting reading, hoping we can go "real"distances on our boat within the next few years as my only experiences have been crewing for others.. Anyhow, drinking water calculation question. You've obviously ventured into my idea of bliss, what was your daily litre bottled water intake?
Before anyone raves about water makers, they can (and do) fail - believe me! Boredom really hit when we thought it was fun to spend a few hours cutting empty bottles into tiny bits, the winner with the most bits got a liquorice alsort![]()
As it was a US yard, our default installation was the Monitor self steering gear. In all those (and my own) I've never heard of such high rates of wear of the steering lines. Did you regularly shorten the lines as advised using the knots at the servo oar?
Well his Lopolight nav lights did fail and AFAIK Lopolight aren't exactly cheap.
