Phoenix of Hamble
All,
As I am in the process of tracking down my ideal boat, and as a consequence I have been putting together a check list of things to look at and check when viewing potential purchases.... its grown a little, and quite frankly, become a little anal /forums/images/icons/crazy.gif, but I thought that others might benefit from this (exhaustive) list of things to check
Now clearly, some things are more important than others, but this way, you can be quite sure that you've missed nothing obvious....
Please let me know if you think I've missed anything!
If anyone wants a copy in Excel, then PM me with your e-mail addy, and I'll send a copy...
boat check list
bilges - wet or dry
bilges - odour free
bilges - clean
hull - epoxied to boot topping
hull - signs of osmosis
hull - general condition/cracks etc
hull - around keel
hull - keel bolts
hull - transducers
hull - p bracket
hull - rudder mounts
hull - through hull fittings
hull - seacocks
hull - deck/hull joint
hull - coach roof condition - soft?
hull - non slip condition
hull - rust marks?
hull - bulkhead integrity/location
hull - anchor locker condition
hull - mountings for winches
hull - mountings for other
hull - paint condition
engine - mounts
engine - external condition
engine - impellor cover condition
engine - fan belt condition
engine - rust visible?
engine - oil? - condition
engine - filters?
engine - accessibility
engine - alternator condition
engine - oil leaks?
engine - bilges under engine?
engine - hours
engine - age
engine - manufacturer
engine - linkages
gearbox - oil?
gearbox - leaks?
gearbox - shaft condition
gearbox - stern glands
gearbox - retainers on shaft to prevent dropping
gearbox - linkages
rigging - bottle screws
rigging - bottle screws in safety zone?
rigging - shroud wire
rigging - date of replacement
rigging - wired off?
rigging - tension
rigging - spreaders
rigging - backstay tensioner
rigging - t fixings on mast
rigging - rivet integrity on mast
rigging - mast condition
rigging - mast corrosion at deck
rigging - mast drain holes clear?
rigging - chainplates - condition?
rigging - chainplates - renewed/rebedded?
rigging - forestay mount
rigging - mast pre-bend
rigging - boom condition?
rigging - gooseneck/track condition
rigging - kicker condition
rigging - topping lift fittings
prop - condition?
prop - type?
prop - age
interior - uplhostery condition
interior - woodwork condition
interior - floor condition
interior - companion way stairs
interior - engine cover condition & removal
interior - headlining
interior - bunks frameworks and condition
interior - chart table condition
interior - shelving condition
interior - fiddles strength
interior - bulkhead condition
interior - doors condition
interior - door furniture condition
interior - lee cloths?
interior - fixings
interior - brasswork condition
interior - table condition
interior - table leaves condition
interior - mast step and fixings
interior - cabinets - condition
interior - cabinets - hinges and doors
interior - grab handles
interior - wash boards - condition
interior - wash boards - security
interior - chart stowage?
electrical - switch panel condition
electrical - switch panel back - neatness
electrical - fuses
electrical - wiring tidyness
electrical - wiring insulation - condition?
electrical - gauges working?
electrical - battery status showing?
electrical - shore power installed?
electrical - RCD present?
electrical - galvanically isolated?
electrical - cabling joints - done properly?
electrical - earths robust?
electrical - inverter?
electrical - main switch - type
electrical - gas alarm?
electrical - battery age
electrical - battery type
electrical - battery condition
electrical - anodes - location
electrical - anodes - condition
electrical - shore power cable condition
nav/instruments - type
nav/instruments - condition
nav/instruments - functioning?
nav/instruments - senders/logs
nav/instruments - back lights working?
nav/instruments - steering compass condition
nav/instruments - steering compass back light
nav/instruments - mast head senders OK?
lights - nav - working?
lights - nav - lense condition
lights - nav - wiring to lights
lights - nav - through deck gland at mast - condition?
lights - nav - switches correct?
lights - interior - working?
lights - interior - switches OK?
lights - interior - wiring condition
lights - interior - master switch wired correctly?
galley - condition?
galley - cooker condition?
galley - cooker gimbals
galley - cooker heat insulation]
galley - worktops?
galley - sink condition?
galley - elecrical/manual pumps working?
galley - gas pipe condition to cooker
galley - drawers condition?
galley - draw retainers working?
galley - storage space condition?
galley - coolbox OK?
galley - hob flame out protection?
windows/hatches - watertight?
windows/hatches - crazed?
windows/hatches - catches/locks OK?
windows/hatches - sign of excess sealant?
water tanks - rusty?
water tanks - access hatches sealed?
water tanks - smell?
water tanks - have they been left full or empty?
water tanks - drainable?
water tanks - filler cap sealing?
water tanks - piping clean and secure?
fuel tanks - condition?
fuel tanks - have they been left full?
fuel tanks - filters - qty
fuel tanks - filters - water in them?
fuel tanks - filters - debris in them?
fuel tanks - filler cap - sealing?
fuel tanks - pipe condition and security
ground tackle - condition?
ground tackle - chain length?
ground tackle - safely stowed?
ground tackle - shackles wired?
ground tackle - anchor winch working?
ground tackle - bow roller - condition?
sails - condition?
sails - dry?
sails - sail bags/covers - condition?
sails - bolt rope/travellers condition?
sails - mast track condition
sails - reefing points - condition
sails - genoa wear
sails - hanks condition
sails - roller furling condition
ropes - warps general condition
ropes - sheets and guys - condition
ropes - halyards condition
ropes - wire halyards splicing
ropes - snap shackle condition
ropes - blocks and pulleys OK?
ropes - spliced and finished properly
gas installation - locker safe?
gas installation - locker vented
gas installation - shut off valves working?
gas installation - pipe work OK?
gas installation - regulator condition?
keel condition - signs of damage?
keel condition - dry?
keel condition - antifouled?
external fixings - secure?
external fixings - spray hood condition?
external fixings - tiller/wheel solid
external fixings - pushpit and pulpit secure
external fixings - pushpit and pulpit condition
external fittings - stanchions posts OK?
external fittings - guard wire sound?
external fittings - aerial mounts solid?
external fittings - dan buoys/lifebelts secure
external fittings - jack stays condition
external fittings - tracks and cars - condition
external fittings - toe rail condition
external fittings - rubbing strake condition
external fittings - dodgers OK?
external fittings - engine controls OK
external fittings - external VHF speaker OK?
external fittings - deck lights working?
external fittings - ensign mount OK?
external fittings - teak decking condition?
external fittings - teak gratings?
external fittings - winch condition?
external fittings - winch handles?
external fittings - winch handles holders?
external fittings - jammers/spinlocks?
external fittings - cleats and fairleads?
heads - bowl condition
heads - pump working?
heads - seacocks OK?
heads - pipework OK?
heads - smell?
heads - dry under floors?
heads - seat/lid cracked?
heads - drain unblocked?
I'm not too anal honest /forums/images/icons/blush.gif, but for me this is a big purchase!
Rgds
Neil
boat check list
bilges - wet or dry
bilges - odour free
bilges - clean
hull - around keel
hull - keel bolts
hull - transducers
hull - p bracket
hull - seacocks
hull - rust marks?
engine - mounts
engine - filters?
engine - oil leaks?
engine - hours
engine - age
engine - linkages
gearbox - oil?
gearbox - leaks?
gearbox - linkages
rigging - tension
rigging - spreaders
prop - condition?
prop - type?
prop - age
interior - fixings
electrical - fuses
galley - condition?
galley - worktops?
sails - condition?
sails - dry?
sails - genoa wear
heads - smell?
Rgds
Neil
