Lakesailor
Which will cost around five times as much as a good second hand seagull and last, if you're very lucky, ten years.Compared to their peers about 50 years ago, Seagulls are great but everything has moved on and IMO you can have all the benefits with a fraction of the hassle with a late model 2-stroke Jap motor.
"I am now sure that OP is even more confused than when he first asked!
If the OP buys anything other than a 2 stroke Mariner 3.3hp.... he's a masochist.
Seagulls may have character.... but the best Outboard ever is the Mariner 3.3 2 stroke.
This photo brings the horror of it all back, and something others have not commented on - that I noticed. I mean the times when it does not start and the string has to be wound around the flywheel again ... and again ... and again.
My Yamaha 4 is another prime example. Despite a relatively easy life and annual professional servicing it seized at about 5 years old (binding rubber bush bearing) and finally died after about ten years when the gearbox housing corroded through in two places.I don't agree. My Mariner 2.5 is a prime example. It's getting towards 9 years old. It starts first pull, has CDI ignition etc, is easy to maintain and looks (other than a few scrapes) virtually new.
And you can't compare a 50 year old 2nd hand outboard price with a brand new modern one. Apples and oranges.
What on earth did you do to it to STOP a Seagull starting? Both the ones I had ALWAYS started first pull - open fuel, push down the button to tickle the carb (dripping 10:1 petrol/oil mix into the sea), choke on if cold and off if warm, and about a third throttle. Low compression engines so the pull was easy.
