yourmomm
Ok. With some angle grinding and fibreglassing, I've figured out how to bring my house bank batteries closer together, using the attached setup.
I know you're meant to fuse batteries within 7" of their terminal. The problem I have is that each of my battery cables to the bus bars is still going to be in the order of 90cm...(of 2/0 cable), so I'm assuming that I have to fuse each battery separately, and then the positive bus bar main distribution line (ie, the wire after the bus bar).
Is this correct? Is there any way to avoid having to fuse each battery separately here?
