burgee
  • Start date Start date
G
Guest
Guest
Not having a windvane, a burgee at the masthead would help but I don't belong to a sailing club. What can I use?
and...... only clean suggestions please!
<hr width=100% size=1>
How about a pair of knickers or some other trophy.
As long as trey're washed - Is that clean enough for you ?
Have you seen the size of ladies' knickers these days? I'd need binoculars every time there's a wind shift.
Serious response is to use streamers from the shrouds. I used to use bits of cassette tape on my GP14 shrouds ..
<hr width=100% size=1>.. whit way roon should it be again ..
No, no - you don't understand.
The Swindlery version is 5 times the price. It's a hand crafted piece of high-tech nautical equipment, machined to fine tolerances and constructed from rugged, rot-proof material. Any resemblance to an M&S sock is pure coincidence. /forums/images/icons/wink.gif
I use just-slack cable ties held up the shrouds by a well wound blob of self-amalgamating tape and they work fine. Ties are better seen if sprayed with day-glo paint.
<hr width=100% size=1>There is nothing wrong with sex on television. Unless you fall off!..
Depends on the size of the lady!
If it was a pair of my 19yo daughters, then I would agree, but if it was a pair of SWMBO's then I could dispense with the spinnaker! (but don't tell her I said so !)
Literally any design you like ..... as most burgees are not registered ......
Design your own - same as I did !
<hr width=100% size=1>Nigel ...
So WHAT does the EU really stand for ????/forums/images/icons/cool.gif
