mikejames
As I replaced the gear lever on my Tohatsu 3.5 today, I thought I would try to unblock the telltale pipe, because it only ever drips.
I pulled the pipe off and poked a wire into the engine block as normal. I picked up the rubber hose that connects to the spigot on the engine to put it back on, and as I did so I saw something shiny inside the hose.
It turned out to be paint that the engine block is painted in- all of the paint on the spigot must have squeezed off as the hose was pushed on , and it appeared as a lump in the pipe, where it has been responsible for reducing the flow to such a miserable dribble even when new that any muck would block off the flow.
Much better now.
(Changing gear lever : easy.. undo two bolts on small panel on front of engine, undo screw, remove old lever , transfer O-rings to grooves in new lever and grease and replace)
Much better now.
