Bulb for anchor utility light
Caladh
25 Oct 2009
Out there again and no longer dreaming
Ok guys where do I get one (yes just one...) This is the trailing night/day light which plugs into a ciggy socket here
http://www.force4.co.uk/force-4-utility-anchor-light.html#.VdG0FJWFN2Y
The bulb is 1watt and is numbered 1892. I can find it on T'internet here
http://www.plccenter.co.uk/en-GB/Buy/EIKO MINATURE/1892
The bulb at a reasonable price but min. order £30 !!!! I can find no other UK stockists and all USA ones are similarly costly when postage and tax added. I'd rather spend the £30 on the newer LED equivalent.
rob2
23 Aug 2005
Hampshire UK
OK, it would help if you had a picture of the bulb itself - I tried Googling all the detail from the box in the picture and none of it seems to define what the bulb is - got everything from domestic light bulbs to miniature "pea" bulbs for a car dashboard. It shouldn't be difficult to find a replacement, whether incandescent or LED once the base is defined, though some LED designs require quite a bit of room.
Rob.
Martin_J
19 Apr 2006
Portsmouth, UK
Seateach in Emsworth sell that Dusk to Dawn anchor light... and I'm sure they have the bulb for it on the shelf.
As you say - I seem to remember it is a relatively unusual bulb.
NormanS
10 Nov 2008
I assume that your anchor light is like mine, and switches on and off automatically. I changed mine to LED. I bought four LED bulbs on eBay from something called buyeasy-fr. the details (for mine) are:-
4x5 SMD 233 BA9S T4W Bayonet Cap 360 HID XENON WHITE SIDE LIGHT BULB.
The total, including delivery, came to £2.99. The light is impressively bright.
William_H
28 Jul 2003
West Australia
I imagine this is the kind of LED bulb you want.
http://www.banggood.com/White-1156-BA15S-LED-27-SMD-Light-bulbs-Tail-p-945904.html
or this http://www.banggood.com/2-x-1156-BA15S-P21W-27-SMD-5050-LED-RV-Car-Light-Lamp-Bulb-12V-p-943963.html
or this http://www.banggood.com/12V-3W-5050-13PCS-LED-Car-Light-Bulb-White+Warm-White-p-914992.html
There are lots of options. Presumably you want no more than 1 w due to current limitations of the electronic light switch.
Many more types of lED coiuld be solder onto existing socket. good luck olewill
