chrishscorp
Replace the filler cap (or a least its O-ring seal)?
+1
I'm not using the stop mechanism, its just dropping to tickover to berth and the engine stops.I still think the 'stop' operation is pulling fue injection rack back too far, stops engine as required but leaves the fuel setting too low to restart immediately. In my case years back it was possible to force restart by fast turnover (compression levers open, fully charged battery,even start handle cranked at same time to assist or at sea even get sailing fast and engage gear to get prop assist on engine turnover before dropping compression levers) Problem diagnosed eventually by very knowledgeable Bukh main dealer then at Poole Quay , long gone now.
Water in fuel a separate problem but needing fixing, new 'o' ring seal for starters, plus bit of grease on seal and cap threads. Where is filler Is it under water when heeled perhaps or raised above deck/floor?
You sound like you know the innards quite well..When the engine is throttled back to idle from high revs on a DV20, the fuel rack closes completely on the fuel high pressure pump until the engine revs are met. The yolk on the fuel pump rack then moves back to open up the fuel pump to maintain idle. Maybe the fuel rack is jamming when it is closing the fuel pump at idle and not returning to the open position.
Once the engine is stopped and the stop solenoid is disengaged, the fuel rack should return to the fully open position (towards the back of the engine) ready for starting. The DV20 always starts with the fuel rack in the fully open position irrespective of where the throttle cable is set.
On the DV20 it is possible to remove the stop solenoid and feel with fingers the positioning of the fuel rack / yolk. in the forward position the fuel rack is set to closed. Don't know if this is poosible on the 10?
Theres a horizontal m6 adjuster bolt/locknut behind the governor. could that hae a bearing on my problems?
If I exercise thew stop valve when it has cut out, would that reset the governor?
I keep replacing the filters, but it doesn't fix the problem,
nobody else has to repplace filters on every outing. I have yet to id the source of the water, but he CAV prefilter and water trap doesn't seem to protect me much.
I dont know anything about your particular engine, but if you are having to do that everytime you go out, my priority would be sorting out your fuel. No diesel engine likes carp fuel.
Finding where the water is getting in ( the filler most likely ) then cleaning the crud out of your tank after draining off the fuel and water. If it is as contaminated as it sounds you will have to deal with it rather than leaving it to your filter, some of these lumps of crud in the tank can partially block fuel lines and tank shut off valves as I found out during a clean out. Sort out the fuel, then look at the engine :encouragement:
.The stop valve appears to be OK, not sticking.
Once the engine stopped again after a couple of hours running I restarted it and it was running very slowly, liuke it does before it eventually stops. I pumped the lift pump manually while the engine was running slow and it accelerated.
Since the governor is supposed to regulate the speed, and the pump should deliver more fuel than is needed, It threw suspicion on the lift pump, so I have removed that for a service.
The water in fuel issue seems to be diminishing now, but we haven't had rain for a few days. I think that reinforces the filler cap diagnosis. Thanks all.
OK, I was "unwatching" some threads that had interested me at the time and yours was one of them so I wondered how you had got on with it.No. as you say lockdown prevented me launching so I'm stuffed for the moment. I cant replicate the circumstances ashore.
