robertager1962
I have a DV36 and just a couple of points that some of the contributors may have slightly muddled (unless they have different configurations to mine) . The fresh water cooled DV36 does not have engine anodes, just an anode in the heat exchanger. Also the electric circulating pump for the water is on the port side of the engine at the front (flywheel end).
They are a low revving engine with a very high torque and provided they are maintained, should last well over 4,000 hours.
A mod that I have added to mine is a freshwater flush which flushes the raw water side with fresh water water when I leave the boat for periods of a few weeks or more. This has definitely helped with corrosion in the exhaust elbow and wastage on the anode in the heat exchanger. It is also a good way to get antifreeze into the raw side of the system.
