petedg
The “Amp” light on our Bukh DV36 engine does not switch off. I checked the 3 wires on the alternator and noticed that the yellow wire had come off the spade terminal. I made a new connection and assumed that would fix the problem but the “Amp” light is still on with the engine running. I also noticed the tachometer seems to be more unsteady than usual Or even not working at all.
I installed a new alternator today which seems to work fine, the “amp” warning light goes out when the engine is started. However, the tachometer and pressure gauge remain on zero and the water temp reads full scale in the red. I’m wondering if there is an earth issue? Any thoughts would be appreciated.
Thanks in advance for your help.
