stevie69p
My 1975 vintage Bukh DV20 has been difficult to start for the last month or so. The boat is fairly new to me (Sept last year) and I just put it down to being an old engine and the rather cold snap we have had of late. I could eventually coax it into life and then it would run ok, but I did notice that the exhaust smoke was quite grey. Anyhoo....
I changed the oil & filter about 6 weeks ago; all was normal with what came out. Changed the engine anode at the same time. I took the boat out weekend before last for a little motor across to a nearby bay just to give it a run. Oil level was fine before that run. At the start of this week I replaced both fuel filters. The primary filter was fairly cruddy looking, and I though there may be some improvement after replacement, but alas no... Decided tonight to remove the stop solenoid, just to check it wasn't stuck against the fuel rack, and removed the high pressure injection pump to check the rack wasn't stuck, etc... only to discover GREY engine oil. Aargh...
So, in making the assumption that the starting issues of late, the grey smoke, and now the discovery of grey engine oil are all related, I'm thinking blown cylinder head gasket. Does the assembled panel here have any nuggets of wisdom as to common failure issues on these engines? I will be honest and say that my diesel engine experience is rather less than petrol stuff, but I did rebuild my last boat's single cylinder Volvo 2001, so I feel fairly confident about tackling this myself.
Thanks in advance for any advice forthcoming. I could do with this like a hole in the head at the moment!
