aidancoughlan
I was down at the boat today doing some stuff & gave a quick visual over the engine. I noticed quite a bit of salty deposit where the cooling water inlet pipe (coming from the impeller pump) enters into the engine block.
There is another hose pipe coming from the same point of access, and taking water to the manifold. I notice the manifold is cracked.
Anybody know what all this salt means ? The plate where the salty deposits are looks like it can be removed with an allen key, and I'll try that next weekend to investigate -but access is very restricted - the flywheel may have to come off to get access - is this a big job ?
What about the exhaust manifold - does this have to be replaced immediately?
thanks for any info...
Edit: I'll try see if I can add some pictures... here goes...
Salty deposits...
Cracked Manifold
Salty deposits...
Cracked Manifold
