winsbury
Just bought a boat with a BUKH DV20 which is giving a feint (read: very annoying) overheat alarm sound but no indicator light once the engine is up to working temperature. The temperature sender has two spade connectors but only one cable. One spade seems to be permanently open circuit while the other varies between around 470 and 550 ohms cycling in unison with the thermostat as evidenced by slightly steaming water leaving the exhaust at the lower resistance readings. The engine is pumping plenty of water and the block is never too hot to touch. There is only one cable from the temp sender and if I ground it the alarm sounds at full volume and the blue overheat light comes on as expected.
I think the problem is one of the following:
1. cable connected to wrong temp sender connector however the spades are different sizes and the cable is connected to the matching size (larger) one.
2. temp sender faulty/incorrect resistance: BUKH does not have any technical information available but at £74+vat+delivery its an expensive item to change without being certain.
3. thermostat opening too late: BUKH suggested a test for this but also think because the block remains touchable it is unlikely again this is a remarkably expensive item at £64 plus £12 for the o-ring +vat+delivery.
4. fouling of waterways requiring Rydlime treatment: again this seems unlikely as block remains touchable and waterflow through exhaust is plentiful.
Does anyone have any technical data or can do some resistance measurements a known working temperature sender as this is my prime suspect ?
