wightacorn
Our DV20 has developed a nasty graunchiness in mid range (2000 rpm-ish) This is not present at low revs nor at high revs and, otherwise, the engine sounds fine. The noise is there whether we are in gear or in neutral and seems to come from the rear of the engine. Initial thoughts from Bukh UK were that it was most likely worn engine mounts. Engine mounts have been replaced to no effect - has anyone any ideas what might be causing this noise?
