Jamesanderton
Active Member
I have a leak from the front crank oil seal, I have had the seal out and found quite a nasty groove in the shaft, cleaned up the shaft and popped a new seal on a good few mm short of said groove, there was however some slight pitting which I had hoped yo have missed when the new seal went on. A week after changing it the new seal is leaking again
Question now is has anyone used a speedi sleeve or some form of sleeve and oversized seal? I have had a quick look online and can only really see any kits (as was suggested to me) but only the sleeves as per size required.
So what are peoples experiences with them?!
