Mistroma
Thank you for sorting all that out!
My thermostat housing bolts just not wanting to budge. They are very solid and I can't see anyway to get diesel down I into the threads.
I will keep trying until the new elbow arrives (hopefully with a new hose - otherwise I will come back to you).
If I am back and running ok with the new elbow and anode then thermostat will rest in peace. I guess the only approach would be to dismantle the exhaust manifold from the side of the engine and get it all to a workshop. Though looking at that now I dont think there is enough space in the engine bay to pull it off the studs sideways!!
At this rate I will be checking in for your head gasket as well!
Avoid removing the head gasket unless you are doing something requiring it. The gasket I have is the one I removed in 1987.
I seem to remember that the manifold is pretty easy to remove and the gaskets are pretty simple in design. I have some material which could easily be cut to make new ones, using the old ones as patterns.
