paris
Hello I have also posted this on Facebook page but wanted as much advice as possible.
I’m after a few pointers, I have a bukh dv20 in my yacht which was laid up last year before my ownership, it was running hot so pulled the t pipe out and cleaned it and it’s helped with cooling and runs well.
But have an issue which initially would only happen when hot when I put it into idle it would bog down to say 300rpm and wouldn’t pick up again, I adjusted the idle speed when it’s cold from 800 to 900 as per the manual but it’s still doing it and today did it when cold, then was a pain to start (which it hasn’t been before), I’ve pulled the primary filter off and it’s spotless also I’m at a bit of a loss.
