Jcorstorphine
I have a 12 year old Bukh DV36 and wish to replace the engine anode. The anode is fitted to a brass plug with a 24mm hex head. The plug is located on the side of the water jacket. I have tried to remove the brass plug but it won't budge. I have a 6 sided hex socket so have a secure connection to the hex plug. My next step is to hire a 1/2" impact driver but I am worried that the force exerted by the impact driver may damage the cylinder block. I have run the engine up to temperature and sprayed penetration oil over the plug. So my question is, could I crackthe cylinder block.
