davidmh
Should the red chargiing lamp, the orange oil pressure lamp and the blue water temperature lamp all go on when you switch the engine key on.? On my Bukh only the red one lights. The engine runs perfectly, the electric oil pressure gauge and electric water temperature gauge both show the correct values.
If the oil and water lamps do not light up anyone like to suggest what could be the problem? The bulbs seen to be in a small individual rectangular plastic housing If I put a meter across each of the 3 bulb terminals with everything switched off should I get a continuity reading on gthe red one and zero on the other two. if they are all the same then the bubs are good. The wiring all looks good. Not sure how long it has been like that because when I stop and start the engine i caanot see the lights.
Any thoughts qwelcome.
