Jaramaz
Active Member
bass reflex, closed or what
They don't. Not always, there are some different loudspeaker basic designs:
- closed box
- bass reflex
- and a multitude of rather special solutions as horns etc
Closed box loudspeaker is nice, has a rather flat frequency response. Drawback is the somewhat lower output power (compared to bass reflex) and sometimes a bit damped working mode - which is possible to hear. A closed box is very easy to put together, not very critical, just see to that it is really closed and put on a lot of damping material.
Bass reflex has higher efficiency (higher sound level) and generally has a lighter sound, higher over tones are not as damped. But frequency curve is not as good, which one may try to compensate with the filters.
Bass reflex tunnel is a critical part of the design, either one has the knowledge of one has to use trial and error (mostly error, unfortunately).
Horns ... are magic. Very high efficiency, as the horn is also an impedance adapter between the loudspeaker and the air. Sound is usually great, design and manufacture very difficult.
/J
Why then do good house speakers always have a hole in the back?!
- closed box
- bass reflex
/J
