sailorman
RUsureDid you not read the first line of his first post?
he mention the "drg of the Olson 30", did he actually say, he had one ???
I had added Troll to my post but removed itI would suggest you take a moment to research who Foolish Muse is......
I don't know why wood/GRP rudders are still made when you consider the leakage you where the GRP and metal rudder shaft connects.
This is the internal structure of one of my rudders. This was subsequently covered in stainless steel sheet tig welded to the shaft and plug welded to the internal webs.
The only problem is its floats so must be held down.
I would love to see the whole rudder. Is it a lovely fair shape? I do not see many welded sheet shapes that are really fair.
IMO, the OP proposal to use a wooden shaft is silly. To have the equivalent strength as the SS tube specified in the plan it would need to be much larger, and so it would not fit into the existing rudder tube.
Don't have a pic of the full rudder but I used quite thin sheet stainless and being fully welded it does have some distorsions.
This rubber is an auxiliary rudder for my wind vane, my main rudder is built the same way but from thicker mild steel (oil filled). this one I wanted light so I could lift it when not using the wind vane.
Pic of main steel rudder and skeg.
Your mind must have been put at rest considering your lengthy and sensible post #25
I have twice in my sailing career broken a solid wood rudder stock - the more recent one was five inches in diameter..
Hi Andy,
I'm flattered you've contacted me. I've read your book and agree with much of your conclusions and advice. I'd strongly suggest you consider a metal shaft. The difference between a wooden one (hickory or other wise) and a stainless shaft, is quite dramatic (order of magnitude scale) and it's just not going to be successful. In smaller craft, where loads are lower this is possible, though size is often an issue, but on your rudder, simply not practical.
This said, it can be done, but the diameter of the wooden shaft would be so large, as to effect the sectional choices you'd have available, with the stock plan form. In fact, I'd also consider changing the stock plan for as well.
The Olson 30 was designed in the early 80's and received a few updates to address issues, like most boats get. The rudder was redone in the early 90's. The rudder was redone again with the Olson 29 and this plan form, is one better suited for the yacht. The only changes I'd make to this shape, is to decrease the radius of the tip a bit. I use this plan form regularly, though with a taller aspect ratio usually, it's perform well across a wider range of incidence.
Working with metal is a pain in the butt for many, but nothing to be scared of. I'd recommend the stainless shaft. I'd do the armature a little differently than shown in the plans, but we all approach things from our various perspectives.
Best Regards,
Paul
I suspect the 1/4 wall stainless tube is somewhat over specified, but does that matter?
I would think it possible to avoid much welding?
I doubt you could screw up the original rudder to any significant degree. Compared to fitting a replacement rudder that may fail. Adding area to a rudder can also be seen as a frangible addition which can be broken off such that you are back to original. Removing some areas should not be too difficult to repair over the cut. Even if you get frustrated it should not take much to get it back to usable condition.You'd think so, but when I completely screw up the build, or I simply throw up my arms in frustration, then I'd be left with neither rudder and be stuck on shore. And that would be the worst of all possible outcomes.
