It is a matter of marketing. You can say you built a pump that is wrecked with Sodium metabisulfite or you can blame the chemical supplier for sending the wrong stuff and then put a warning in the manuals that only Spectra pickling chemicals can be used. Since the pump will not take kindly to the most widely used chemical in water maker use I believe my version.
From the manual:
Warning! The Spectra SC-1 Storage compound is specially formulated to be
used as a Spectra system preservative. Sodium bisulfite or metabisulfite
should not be used as a preservative in the Spectra systems. Use of
sodium bisulfite will attack materials used in the Spectra systems and
void the warranty.
From the manual:
void the warranty.
