Another misunderstanding. You ask us to keep things in perspective.
You state the forum has concluded that insurance premiums will rise because of thev loss of one heavily used example.
I have just re-read the last 3 pages. I ASKED a question- post #142-will premiums rise.
Another poster suggested they COULD.
Hardly a conclusion...........................
You are right but whats a little exaggeration between friends!!and even fellow motorcyclists - now I was going round this corner, leaned over and ................
RCD is about the state the new boat leaves the factory in.
Actually the RCD is more about EU protectionism than anything else.
I cannot help the feeling that much of this thread has been taken up by poorly informed criticism of one design and designer. Surely the real issue is that most modern cruising boats and cruiser/racers have bolt on keels. They have advantages in terms of construction cost and boat performance. There are thousands of them, and very few actually fail. Most that fail do so due to gross misuse. If you bash the leading edge of the keel into a rock at full speed you should not expect the boat to have been designed to come away completely unscathed. Yachts are designed to be strong enough to be stood on their keels if dried out on a falling tide. They have enough keel attachment strength to withstand a grounding under sail, but such an event should be followed by an immediate check for any leaks, cracking or other damage. For a fin keel boat to have been grounded more than once and yet not to have been subjected to an expert survey afterwards strikes me as coming into the realm of gross misuse. The CR accident was a tragedy that might have been avoided if the keel attachments had been thoroughly examined after each previous grounding. This tragedy was IMHO as much a failure of care and maintenance as it was of design.
I clobbered a rock up in Loch Scavaig in 2012.
What boat can be bought today that does not have this type (Liner) used in the construction?
Is that the Jeanneau 45.2 mentioned on your "About Me" page? I think that's a stunning boat.I am glad that I own a 1998 boat that was quite well built and has no inner liner inside the hull, but visible glassed in stringers.
I suspect the above analysis may be deeply flawed.
A reduction in the strength of the hull laminate would cause the loads not to be distributed properly, overloading each keel bolt in turn.
Analysis by analogy to fish cans and a disdain for computers sounds OK in the bar, but probably misses the point.
Not sure your comments are fair. Tara's comments regarding the effect on Bruce Farr designs is relevant as is his point that older boats might need uneconomic repairs.
The problem with any opinion on the CR is we don't know how severe any of the acknowledged impacts were or how thorough any survey was nor how good any repair attempt was. Yes we know the repair was inadequate but like many structural failures in both buildings and planes it's easy to be clever after the event. In my career I have investigated a number of structural problems and failures and none of them were due to any one factor - usually 3 or more contributing factors.
I note the comment on adding steel saddles and while possible it's one that has to be done with care as alterations like this can cause loads to be redistributed but often to areas inadequate to take the additional load. I have reviewed designs where the addition of a member caused the over stressing of an existing structure that otherwise would have been OK.
None of the failures that I have examined involved any level of stupidity more an understandable error usually combined with other factors and all have left me with a feeling of "there but the grace of God go I. "
