My boat has a brown staining to the gelcoat along the waterline - any suggestions how to clean/remove it?
I have tried Y10, 3M compound, Viakal, Oxalic acid.
I use Y10 to remove the brown staining, have you left it long enough, the instructions state 10 minutes, I have had to leave it a little longer in the past, depends on temperature etc.
Y10 again i say!
However, i have similar staining, which is almost of a gritty feel too. I use shampoo,then Y10, then i seal it with wax.
But as others say, leave it soak for a while. I did my boat last week and left the Y10 dry on in the sun for 20min which brought it up in an amazing white colour it turned out like new.
I would say that Oxalic acid or one of those rust converter type acid preparations would fix it. You apply and allow 10 minutes for it to work.
I have found lemon juice will also move the stain. olewill
In Pompey hardbour we seem to get diesel residue with is electostatically attracted to the white gelcoat above the waterline.
We remove it wilh Cillit Bang
