Tranona
What's the aim of these steps? It's not going to keep water away from the wood, as the rest of the rudder is not sealed or specially protected, just painted. And I don't think the bolts need to be protected from the wood - I'm satisfied that the corrosion is due to using the wrong stainless for the job, not tannin attack. In any case, the holes are pretty tight-fitting, so while I'd be able to soak a bit of plain epoxy into the edges of the wood, any thickened paste I applied would be removed again as soon as I drilled a hole big enough for the bolts.
Cheers,
Belt and braces! The holes will have unprotected end grain and you are reliant totally on the sealer. Have just had to repair some rot in my hull when I removed the anode fittings, because the person (not me) who fitted it did not epoxy the holes but relied solely on the sealer. One was OK but the other had let water in. Maybe I get a bit paranoid about such things, but when you have the same boat for 30 years you learn about long term consequences of your actions!
