Norman_E
Yes it does seem to be fuse or switch, if you have red probe on +12v terminal at compressor and black on negative near fuses and get 13v that would show power at compressor but negative fault, option would be to disconnect both at compressor and to run cable direct to compressor terminals from battery, black first and then red, I suspect compressor would run.
DON'T DO THAT. 12 volt compressors are run in the way I indicated in my post on this thread. You risk damage if you try to power the compressor other than through its own electronic controller. Its OK to power directly to the control box input terminals, but not to the compressor terminals.
