Brent Swain
Wansworth
8 May 2003
SPAIN,Galicia
Anybody remember him on theses forums,came across his name a boatbuilder built a very nice bilgekeel 36 footer and sailed across the Pacific he the builder/sailor thought bilge keels gave a less rolly ride,interesting
DownWest
25 Dec 2007
S.W. France
Difficult to forget Brent. The idea was OK, his evangelism was a bit OTT, along with dissing well respected designers, because they asked legit questions about his design knowledge (lack of..)
Banned off most forae.
Laminar Flow
14 Jan 2020
West Coast
I've met and spoke to him (briefly) personally and I've seen his boat. To call it very nice looking is overegging it just a little.
I have also seen and been on a number of his designs and if you have a penchant for rather utilitarian looking things that are perfectly happy to sacrifice any pretense to hydrodynamic efficacy for ease of construction, then, by all means, fill your boots. In the past , and to satisfy my interest into bilge keels, I did some research into their design. Swain's ideas on them, including a toe out attitude, seems to contravene most of what is known about any of the more successful applications. The supposedly less rolly part of the equation has probably more to do with their shallow draft and a reduction in the radius of gyration over the deeper fin keel variant. To be effective in roll attenuation, requires low aspect ratio and speed. He got the aspect ratio right, which is not so good for sailing to weather. I'm much less sure about the speed component.
For what it's worth, there was a time in the 80's when all sorts of people sold steel boat plans for the home builder - that ship has sailed. There is absolutely no economic case to be made for that now.
Wansworth
8 May 2003
SPAIN,Galicia
There was a designer back in the 1980 Feltham who had quite a success with twin keels …..Seawolf26/30.I had a very nice Alan Pape designed hull and deck in steel which I fitted out which is still going strong in the rias But as usual with a mature fitting out costs can run away,still it was a good sea boat for much less than a factory produced craft
Laminar Flow
14 Jan 2020
West Coast
I agree that Alan Pape designed some fine looking, and seaworthy yachts.
The French seem to have discovered twin keels as of late the performance of which has nothing in common with that of some of the early British efforts. For cruising boats twins have much to recommend them.
Tomahawk
5 Sep 2010
Where life is good
That will be because French think what if I try this. The English seem to look forward to a better old fashioned design.
Lightwave395
14 Aug 2016
Me in Cowes, the boat back in UK now at St Mawes
There bilge keels and there are twin keels
'Interesting' design I saw in the yard in Southern Brittany last year - the French designer Pierre Roland has a couple of Pogo-like designs, spartan but functional interiors, the owner let me have a look around, I'd hardly call it bilge keels, as you say:
Laminar Flow
14 Jan 2020
West Coast
Yes, I mis-wrote. I am aware of the differences between bilge and twin keels and I used to own a Griffiths' Waterwitch (bilge).
My interest at the time was specifically towards the use of asymmetric profiles. The French take on twins is to use fins with a much higher aspect ratio and less focus on shoal draft. That said, a single fin with that slender a form would be of course considerably deeper.
Sirius also offers their boats with a twin option and they claim that there is as good as no sacrifice in performance for that choice. I have yet to see that substantiated. Regardless, the RM seem to have good performance with their variant.
For shoal water cruising the French variants would encounter much the same structural issues as any other boat with a short keel root would in the event of a grounding. I'm also not sure how well they might fare resting on that single skinny rudder tip when refloating in a bit of a swell either.
So, for sheer cruising practicality, if not so much for performance, the British take on twins is not necessarily all wrong. Performance, IMHO, comes in many different flavours.
Tomahawk
5 Sep 2010
Where life is good
I saw a write up of a French shoal draft twin lifting keel job. Draws all of 18 inched boards and rudders up and designed to take the ground... best part of 2m boards down. Think it was built by Pogo?
Laminar Flow
14 Jan 2020
West Coast
A single lifting keel is quite enough of a complication and maintenance issue on it's own (been there, done that). Not sure how doubling up on that is overly beneficial.
Most French shallow draft boats seem to have centre boards these days with all inside ballast (Ovni, Boreal etc.)
The Haber 34 motorsailer has 4 centre boards and a lifting rudder for the maintenance obsessed and to apparently achieve selfsteering ability, something that could be much more easily, and cheaply for that matter, be achieved with an autopilot.
DownWest
25 Dec 2007
S.W. France
There is a 30ft in the local marine with twin lifting dagger boards. At least they are out of the centre of accomodation. Might be a one off and in ply. Tackles look light, so not heavy boards, likely internal ballast.
Tranona
10 Nov 2007
Bit like the Fairey Atalanta from the early 1950s. Designed by Uffa Fox.
